 [ 13 posts ]
Sat Aug 06, 2011 10:40 pm
What's 7ur?
Sun Aug 07, 2011 7:44 am
Deafy Dad wrote:
What's 7ur?
Scroll about 1/2 way down that page and look for the Umbrella Reflector, part number 7ur.
Mon Aug 08, 2011 11:32 am
ltwimberly wrote:
The PCB umbrella reflector is meant to block spill to the sides. You can't mount a reflector and a speedring at the same time though. You'd need to mount the PLM using the umbrella bracket on top and mount the reflector using the fingers.
The 7UR is designed for use with a shaft mounted PLM. You cannot mount any other modifier to the light when using the speedring mount for PLM.
 [ 13 posts ]
