 [ 11 posts ]
Wed Aug 17, 2011 11:35 am
wenzone wrote:
I am also able to get the white dash under the channels after fiddling with it,
Is this in the OPEN MEMORY> OPEN FROM STUDIO screen? If so, try using a different frequency.
wenzone wrote:
the test light on the CSR+ some times goes orange/red from green as well).
This means the reciever is getting a fire signal, and is normal and wanted.
wenzone wrote:
(I will admit right now, I AM using fairly generic/cheap power bars.)
Those are typically the least likely to cause problems.
wenzone wrote:
I really hope it's a "settings issue" or just because it's not a high quality power bar or something, because if they are this difficult to get to run smoothly plugged into a common power bar to the wall, I'm concerned relying on them on location with the battery power could end up being a bad idea.
If it was power chain related, the Vagabonds are a clean power source. I have yet to come across an instance where a Vagabond was the limiting factor in getting the remotes to work.
Also, everything you try, do one at a time. This way you can determine what is the actual cause for future reference.
 [ 11 posts ]
Users browsing this forum: No registered users and 56 guests
