Mon Aug 22, 2011 9:00 am
Is there a way to change the CyberCommander's default ISO value in such that it remains persistent while changing batteries? If not, then can it be saved to an SD card?
Mon Aug 22, 2011 10:15 am
ISO will revert to 100 when power is lost. Also, this is not a function that is saved as part of a set up. However, you can offset ISO with CAL (in the same screen). CAL can be saved as part of a set up.
Mon Aug 22, 2011 1:15 pm
What are the odds of adding this in a near-term firmware update?
Mon Aug 22, 2011 2:30 pm
I can't give odds. Too far out of my control. However, your suggestion has been noted.
Mon Aug 22, 2011 3:24 pm
Thanks. IMO, it would be best to make ISO a "sticky" setting, such that it would always revert to the most recent setting following a hard power reset.
Users browsing this forum: No registered users and 29 guests
