 [ 14 posts ]
Wed Sep 21, 2011 5:08 pm
BDP wrote:
I'm not familiar with the Norman, but it almost seems as if it is missing something. It seems like there should be a threaded hole in the end of that pole so that you can screw in a standard mounting stud.
In any case, to work with what you have, you could add a SuperClamp near the end of the boom. It clamps securely to the boom (or other things if need be) and includes a normal stud that you can mount the AB to. You might want to get an extra long stud, separately, to give a lot of grip area for the AB.
http://www.amazon.com/Manfrotto-035RL-Super-Clamp-Standard/dp/B0018LQVIA/
It is a pretty standard item to have, so that you can clamp to stands, booms, structures, etc. A generally useful piece of kit, and once you have one, you will probably want another.
yes there is a hole threaded but pic didnt show bec its on other side of it. it wont fit in AB anyway. I looked up online norman's site it looks they dont do brass stand tip. it looks like they do offer others but im gonna call tomorrow and see what i can do. ill look into clamp but i wanted to use boom NOW!! :( i guess Jerry rig with duct tape would do for now... Feels like im red neck right now lol
Wed Sep 21, 2011 5:11 pm
BDP wrote:
Also, independent of how you resolve this particular issue, it sounds to me like you may have some safety issues.
Ensure your light stand is properly stable and sandbagged at the base, that your boom counterweight is properly positioned to balance the arm.
If you "need" to use duct-tape to mount your AB and/or octa on a boom, then you probably shouldn't be mounting them to your boom, in my opinion, until you have the right mounting hardware. At the very least, you are risking damage to your gear, but worse, you could be risking injury to yourself or others.
When you mentioned an AB and a 70 inch octa on a boom with duct-tape, I actually shuddered. I am hoping I misunderstood and imagined something far worse than what you actually meant :shock:
Nope didnt misunderstood lol... i was scared too lol i wont be using octagon with boom, i have other smaller softbox that weights more lighter.. I ll look into hardware later today see if i can get something from there.
Wed Sep 21, 2011 5:12 pm
Technical Support wrote:
Deafy Dad wrote:
mounting on 3/8" (811779), 1/2" (811744) and 5/8" (811793) stand tops which would be right size tip?
Sorry, I need some clarification. Did you try various tip sizes or mounting block sizes? How did you try different ones?
didnt try nothing, just copied from normans website see if i needed right one.. 5/8" is what i needed..
Wed Sep 21, 2011 5:13 pm
Luap wrote:
Looks to me like the standard brass 5/8" "stand coupler" is missing from the Norman Boom. From the pix, it won't fit any studio flash
Obviously! :roll: dang! I guess i got ripped off , oh well... part of learning process i guess.
 [ 14 posts ]
Users browsing this forum: No registered users and 36 guests
