A bit different for my shoot than the other photographer's shoot.
Quote:
For clarification, the Dynalite packs did not work on location when powered from the VML, but back "home", the same Dynalite packs in the same VMLs did work well?
Yes for both.
Quote:
What were the power settings on the Dynalite packs and how long did you give them to charge?
In both cases, we do not remember exactly but with my situation, I expect I started with a low power setting, no model light. To the best of my memory, I think I got a "pack charged" light but would not discharge. I changed heads, cords, etc but only had one pack. Initially thought it was my pack but again, when I used the same pack/heads at hotel room that night, pack powered up and head discharged just fine.
The other photographer had his model light on initially but turned it off. His pack initially did not charge at all. Later did (20 minutes) and at studio worked as it should.
