 [ 6 posts ]
Thu Sep 24, 2015 1:54 pm
We are ready to ship a new bracket designed to securely hold your Vagabond Mini Lithium to your lightstand, even while on the move.
There are two pieces, a bracket and a clamp. You can purchase the pieces as a set, or individually, for those of you who already have a component (notably, a suitable clamp)
The set can be found here:
http://www.paulcbuff.com/vmbrkt-set.php
The individual pieces can be found on this page:
http://www.paulcbuff.com/mountingblocks.php
Sat Sep 26, 2015 10:39 am
And there was much rejoicing!!!
Thu Oct 01, 2015 10:22 pm
The arrives with tab shows the wrong product.
Thu Oct 01, 2015 10:38 pm
Indeed it does! I will get with our web team ASAP. Thanks!
Fri Dec 11, 2015 3:02 pm
will this work on most light stands? I use impact light stands. No jiggles or wobbles?
Fri Dec 11, 2015 4:29 pm
This uses the same metal mounting block as current AlienBees and Einstein lights. It tightens down snugly on 5/8" studs and the bracket is snug on the mount.
 [ 6 posts ]
