Wed May 11, 2016 1:21 pm
Would the Kelvin temp on the AB and White lightning be 5500?
Wed May 11, 2016 3:31 pm
I believe the Einsteins are more geared toward constant white balance.
Thu May 12, 2016 7:00 am
I only have AB and lightening. I do know if you add some modifiers it will change the Kelvin temp mainly wondering about with out modifiers.
Thu May 12, 2016 9:06 am
The nominal color temp is 5600K at full power. As you reduce power, as with any Voltage controlled light, your color temperature will shift down by about 80K per stop.
Thu May 12, 2016 11:25 am
Thank you I wasn't too far off in my thinking.
