Sat Jun 11, 2016 6:30 pm
For some unknown reason, one of my units keep turning off.
Is there anything I can do on my end to remedy this?
Sat Jun 11, 2016 9:28 pm
Likely, it is a setting in a Cyber Commander, if you have one.
If so, check this channel for a white dash under the graph (white matches the text for CH and Menu in the corners). If there a gray dash instead (gray matches the graph lines, and is hard to see), the channel is in standby.
You can turn the light on, then go to OPEN MEMORY=> open from that channel (instead of STUDIO)
Or
You can go to SETUP=>Light Settings=> select POWER=> set to on from standby.
If there is no Cyber Commander, let me know!
Tue Jun 14, 2016 11:05 am
Thanks... yes, it was the setting on the CC. :D
Users browsing this forum: No registered users and 9 guests
