Site Admin |
Definitely keep LV off. Also, try loosening the hotshoe. As you tighten the locking nut, it will draw the contact up off the hotshoe. As a trouble shooting step, loosen the nut all the way and press down on the adapter as you take a photo. It will likely then fire. If the adapter is too loose to stay on, you may have to shim between hotshoe rails and the locking nut (thick tape on the bottom of the nut as an example). Canon seems to be very particular about the contact, less tolerant of manufacturing variations than other brands of camera.
