I ask this because I want to test out a flash tube from an AB1600 on an AB800 which i suspect is malfunctioning, but i want to see if it is a flash tube problem or the whole unit is messed up.
The problem with my AB800 is that at any power level, the flash tube pops with a very weak flash. On top of that, I see the red dump light constantly on, so it may be an issue with the capacitors too, I don't know.
What can I do?
Update: Nevermind the question on the subject box, it seems as though the flashtube is the same one, I will test out a working one on the AB800 tomorrow, but any clue what might be happening? I am using the test button to trigger the strobe btw.
