I've had my AB800 for approx 2 months and other than setting it up over my still life table it hasn't moved much. Yesterday I moved it around the house several times to different locations to take some portraits. Each and every time I moved it I turned it off, unplugged it and then moved it across the room or into the next room. I was not rough in anyway when I moved it but when I turned it back on the modeling lamp would not come back on. To get it to work again I had to unscrew it and then screw the lamp back in, but not too far or it would turn off again. I was not turning it any harder than you would normally screwing in a light bulb. I tried a different bulb, same result. Needless to say I'm a bit frustrated and not sure how to resolve this since it's just a standard bulb socket, how could that be broken?
