Luap wrote:
We have tracked down the CC range problems to the antenna foil sometimes touching the can that shields the actual transceiver required by the FCC. This has been corrected in production and any users suffering very short range should contact us for replacement. We are also doing improvements to the antenna tuning to further increase the range.
Paul,
It appears that part of the range problem has been solved by correcting the issue with the foil touching the can, but you indicate in the same post that "we are also doing improvements" in antenna tuning. This gives me the feeling that the antenna tuning remains a work in progress. In another thread titled "CC + CSXCV + Einstein = Poor Range and Reliability", you stated that "Several mods are going in Einsteins now shipping".
1) How (assuming they do) do these Einstein "mods" relate to the CC/Einstein range issue?
2) Is the CC antenna tuning a completed task, or is it a work in progress?
3) Bottom line: for those of us experiencing CC range issues with Einsteins, would we be better off waiting a few weeks while you continue to get this nailed down?
