Mon Sep 13, 2010 10:38 pm
Newbie of course - any situation where you use the diffusion sock and the direct-light blocker at the same time?
Thanks,
Paul
Mon Sep 13, 2010 11:30 pm
I thought using it without the blocker might give a bit of a hot spot but really don't know if that's the case. Generally I leave the blocker off if using the sock...
Tue Sep 14, 2010 10:22 am
Even with a diffuser, some light will travel straight, causing a hotspot. By using the light blocker, all light will be bounced light, then diffused.
Tue Sep 14, 2010 12:29 pm
So, the blocker is also a bouncer! I'll give it a try.
Thanks,
Paul
Users browsing this forum: Google [Bot] and 18 guests
