 [ 12 posts ]
Thu Oct 14, 2010 11:20 am
Dig the ads. Curious to see the results of where the Einstein in Action mode falls under the 'Color Temperature vs. Power Settings' section.
The published results should seem very appealing to potential customers (and yes, I understand this is geared as an advertisement). However in all fairness, the competitors listed there don't benefit from the color-specific modes, so some folks may balk at this not being exactly oranges-to-oranges. You know how the anal the interwebs can be sometimes... ;)
Thu Oct 14, 2010 12:26 pm
I believe the lights used in the example (particularly the Profotos) were due to the wide spread assertion that they are immune from color shift as power is changed. The point is to show those lights don't have as consistent color as "common knowlege" would dictate, but have the same color vs. power profile as any other voltage controlled flash (including the Alien Bees and White Lightning).
Color temperature on the Einstein does increase in Action mode. A comperable chart can be found in the manual here: http://74.208.158.244/files/manuals/pdf/e640_0310.pdf
 [ 12 posts ]
