 [ 12 posts ]
Wed Dec 09, 2009 12:37 am
vmaxguy wrote:
I was writing my reply when the moderator posted, so I didn't see it before I posted. The moderators post says the strobes fastest flash duration will come from the strobes full power. I thought the shortest flash duration came from the strobes lowest power, so my answer may be wrong. I am not an expert in strobes, but I am guessing the moderator made a mistake.
Tech support made no mistake. This has been discussed many times. Almost all studio flash units use variable voltage control, and indeed the duration gets longer as you reduce power.
See: http://www.paulcbuff.com/forums/viewtopic.php?f=5&t=59
and excellent explanation at: http://robgalbraith.com/bins/content_pa ... 0044-10303
Luap
Fri Dec 11, 2009 1:47 pm
The first question is, did you meter you lights? Second, what was the metering of the ambient light? Most of the time you will want to take the shot at the peak of the jump to to totally freeze the action. If you want some ambient light to register, taking the shot at the peak of the jump is key.
 [ 12 posts ]
Users browsing this forum: No registered users and 5 guests
