Sun Jun 05, 2011 3:37 pm
Can a Vagabond II be used to charge camera batteries in a pinch? Will I risk damaging either the Vagabond or the batteries I am charging?
Sun Jun 05, 2011 5:01 pm
The VBII will run/charge just about anything that takes 60-Hz 120-V power as long as it is less than the vagabond's max power output. Charging normal camera batteries should be fine.
Sun Jun 05, 2011 6:36 pm
Thank you PE
Users browsing this forum: No registered users and 36 guests
