 [ 47 posts ]
Thu Mar 10, 2011 4:45 pm
not working for me bought a pny sd card and fat formatted it no go
Thu Mar 10, 2011 5:24 pm
ericski wrote:
Doing that I don't get any flashing back screen after selecting it. The light reboots, still says v.22 but one of the hex files is deleted from the card.
I will have to look further into this matter.
Thu Mar 10, 2011 5:26 pm
It is a 2GB or smaller Micro SD card, right? Not a Micro SDHC or SDXC? Also, that is FAT and not FAT32? Are you using a PC or Mac?
Thu Mar 10, 2011 5:53 pm
Yes it is its a pny 2g micro sd card formatted to fat tried it three times using windows xp
The fan goes on few a second then stops.also notice there is no file in the configs folder
Fri Mar 11, 2011 2:53 pm
Ericski and aaalegre: Have you tried re-downloading the files from the web?
Fri Mar 11, 2011 2:58 pm
Yes I have three times
Fri Mar 11, 2011 3:34 pm
I downloaded it twice.
Fri Mar 11, 2011 5:57 pm
You should have mail (or will soon).
Sat Mar 12, 2011 5:54 pm
I got the upgrade to work by switching from a PNY memory card to a SanDisk memory card.
Wed Mar 16, 2011 11:01 pm
First of all. I'm a Computer Engineer. I upgrade firmware all the time, electronics all the time. I understand how this works. However tonight on my second upgrade I go to insert my micro sd card in the light and for some reason this one does not spring... I try to pull it out...only to find it has now fallen into the housing!!!
That's right I have a micros SD card shaking around inside....so now what??
Is this not safe to use anymore?
Am I going to short out the light?
Can I get this replaced and get my stupid disk back that I just spent $12 on?
I have a shoot this weekend. I had no clue this was going to happen.
Tech support is this safe to use with a disk floating inside the housing?
Paul can we get this replaced (hopefully with version 3 anyways since I'm waiting?)
Community be careful when inserting....not sure why my slot for the card is not installed correctly to allow the card to slide into the inside of the housing...
I want to take the housing off but I'm guessing that's against the warranty. If it doesn't kill the warranty can I take those 4 screws out and get that micro SD card out?
Any help ???
 [ 47 posts ]
