 [ 14 posts ]
Wed Mar 09, 2011 3:47 pm
Or, if you meter the main light and get, say, f/11; then meter both lights and get f/11'5, then your fill would meter about f/8 by itself (f/8 is half of f/11, so f/11 plus one half of itself would be f/11'5). Due to differences in how the light falls on the subject, this would only be an estimation.
If you are using a regular flash meter and if the slave flash has a test button, you can "arm" the meter and press the test button on the slave flash. When the meter senses the flash, it will take a reading. You will only need a way to supprot the meter at the subject's location.
Thu Mar 10, 2011 12:41 pm
This is extremely helpful. Thank you. I've looked at the strobist website but still couldn't find the answers I'm looking for.
So lets say I set my main flash (Alienbee800) to read 1/125 F8. Should I set my fill (slave) at 1/125 F5.6? Then what should my camera be set at....the main? Or do I measure both of lights together? :?
Thu Mar 10, 2011 1:20 pm
I did not see your last post.....sorry.
Thu Mar 10, 2011 1:28 pm
Yes, the additive properties of light will require you to meter both simultaneously.
 [ 14 posts ]
