 [ 18 posts ]
Thu Jun 16, 2011 8:59 am
Chico wrote:
TS- Can you just ship them out already formatted until you find a solution? I'm a mac user and i just order mine today.
Formatting does not appear to be the source of the issue, therefore that would likely not help.
Chico wrote:
Is the SD card just for storing settings or firmware updates?
Both.
Thu Jun 16, 2011 12:13 pm
Both.
So i should be o.k with mine? I'm not planning on storing setting as they change for me every time i shoot. My concern is firmware updates? Do i need a PC for this?
Thu Jun 16, 2011 1:27 pm
Firmware updates actually seem to be OK. Yes, a PC or Mac would be required, as well as a means of writing to a microSD card. The only things about Macs is formatting to FAT16. It is only possible if you know comand lines.
Thu Jun 16, 2011 8:40 pm
I appreciate your efforts on this issue. I have been out of town and to busy to follow up until today. I am still having the same problem so I look forward to seeing the solution when you post it.
Fri Jun 17, 2011 4:33 pm
We have a possible resolution that is very promising being evaluated now. If it passes evaluation, I would expect it available early next week. This is subject to change as necessary.
Tue Jun 21, 2011 4:22 pm
http://www.paulcbuff.com/pcb2009/cyberc ... tions.html
New firmware has been posted to address this issue. You may use the existing cards to perform this update.
Fri Jul 01, 2011 1:19 pm
It solved the issue.
Thanks for your quick turn around. You're great!
Thanks again
Patrick
Mon Jul 25, 2011 1:02 pm
Fixed mine too. It works perfectly now!
Thanks,
Steve
 [ 18 posts ]
Users browsing this forum: Google [Bot] and 55 guests
