 [ 13 posts ]
Fri Oct 21, 2011 7:54 am
Just cheked on the CC, it was on standby..damn me.
Tomorrow I'll check it on the field and I'll tell you if everything was back to normal.
Thanks again for the support !!
Thu Oct 27, 2011 7:54 am
Hi,
Thank you again, It turned out that all the lights were on Stand By...
Don't know why..
But finally I can use my Bees properly !!
Thank you very much !
Thu Oct 27, 2011 10:10 am
sczoron wrote:
Hi,
No problem, that is why we are here. However, if you look at the bottom of the graph, each channel should have a white dash. This means they are "ON" (as opposed to standby). If those dashes are gray, the light is set to STANDBY. This is an immediate indication of the light's status. Also, there will only be a blue bar if the light is on. So, if you see blue bars, the light should work. If you do not see blue bars, then the power is either at minimum or set to STANDBY, then you would check the dashes.
 [ 13 posts ]
