 [ 13 posts ]
Tue Feb 16, 2010 10:41 pm
I have three of these units and I had the same problem, it must be a voltage or ground issue as it happens with different cameras and software. I use a radio pugged into the CompuScene to trigger the strobes to eliminate the problem. I would be interested to hear if there is a way to use sync cord when tethered.
Dan
Fri Feb 19, 2010 1:56 pm
To: Anatoli,
Thank you for the suggestion about the live view disable IT WORKED.
I guess that I should have read the book a little further.
To: Tech Support,
Thanks to you, also, for your efforts in trying to solve the problem.
As you can probably determine the problem was not with the Compuserve but with a camera setting.
THANKS TO ALL FOR THE HELP!
Fri Feb 19, 2010 3:16 pm
That was actually my first thought, though i don't know why it would fire a light but not the Compuscene in live view.
 [ 13 posts ]
