ULTRA COMPUSCENE http://paulcbuff-techforum.com/viewtopic.php?f=8&t=246 |
Page 2 of 2 |
Author: | SteelyCam [ Tue Feb 16, 2010 10:41 pm ] |
Post subject: | Re: ULTRA COMPUSCENE |
I have three of these units and I had the same problem, it must be a voltage or ground issue as it happens with different cameras and software. I use a radio pugged into the CompuScene to trigger the strobes to eliminate the problem. I would be interested to hear if there is a way to use sync cord when tethered. Dan |
Author: | CTC [ Fri Feb 19, 2010 1:56 pm ] |
To: Anatoli, Thank you for the suggestion about the live view disable IT WORKED. I guess that I should have read the book a little further. To: Tech Support, Thanks to you, also, for your efforts in trying to solve the problem. As you can probably determine the problem was not with the Compuserve but with a camera setting. THANKS TO ALL FOR THE HELP! |
Author: | Technical Support [ Fri Feb 19, 2010 3:16 pm ] |
That was actually my first thought, though i don't know why it would fire a light but not the Compuscene in live view. |
