 [ 13 posts ]
Thu May 09, 2013 5:04 pm
Kaelaria wrote:
I keep the unit plugged in for storage so it's always topped off.
We do not recommend leaving the lithium battery connected for long periods of time. I cannot say that is what caused the battery failure, though it is not generally good for the battery.
Fri May 17, 2013 1:54 pm
In my mind, I can't think of anything else that would have caused it. 100% my fault. Somehow I never even realized the special instructions were there, I was following the storage procedures I had always used from the older VII systems. The Mini was always stored at 100% and plugged in. Now I will follow the damn instructions!!
New batt works perfectly BTW, thanks guys!
When storing your Vagabond Mini™ Lithium, verify that it contains more than 25% charge.
If the charge status is lower than 25%, apply a partial charge to 50%, turn the system OFF,
disconnect the battery charger, disconnect the battery and store in a safe, cool, dry place
away from flammable materials. While the battery can be stored safely in any state
of charge, it should be used and partially recharged every three months for best
battery life, and to avoid ruining the battery’s components. Do not charge the
battery to 100%, and then store it.
Sun May 19, 2013 10:32 pm
steveho wrote:
I'm having a problem with my Vagabond Mini Lithium power supply. Recently, it's been acting up. In the past, I've just run it for many photo shoots and when it gets to about 1/4 power, I'll charge it overnight. I've been running it in this manner for about 1.5 years now. It's lasting me about 1000 shots between charges.
I've probably used it for about 15,000 shots (1 AB400 usually running about 1/8 to 1/2 power for each shot). So I've probably charged the unit 15 times.
Now I'll charge it and it'll last 1 or 2 photo shoots (60-100 shots each). It will read 3/4 power, and then suddenly die. Is this normal? Is the battery done for already? I've owned it for 1.5 years now.
The VML battery should last for 300-400 charge/recharge cycles. This is slightly longer life than SLA batteries.
There are higher cost LiFePo batteries that are more expensive, larger and heavier per watt hour, but they offer about four times the charge/discharge life. Also, they are the safest type of Lithium batteries available. We plan to use these in future VML versions.
BTW, the LiCoxNiyMnzO2 (NMC) type Lithium batteries used in VML are far safer than the older LiPo batteries that recent caused all the Boeing aircraft problems and the early iPhone and laptop "exploding" batteries.
 [ 13 posts ]
Users browsing this forum: Majestic-12 [Bot] and 33 guests
