 [ 16 posts ]
Wed Jun 16, 2010 12:13 am
I believe the price difference is $20 per CSRB+. While you won't be able to remotely adjust your brand X flash units, you will still be able to group them, individually fire and meter them, name them (Main Light, Fill 1, etc). Personally I wouldn't bother with the CC without the CSRB+ units - just use a $59 CST instead.
Wed Jun 16, 2010 12:33 am
Luap wrote:
I believe the price difference is $20 per CSRB+. ....
Thanks Oh Mighty Leader....
The prices are $US69.95 and $US89.95, indeed a $20 difference, but "Downunder" the prices are $AU123.20 and $154.00 ($30.80) and the AC powered ones are not available at all !!
On a not totally unrelated note, I noticed that today Phottix released their "Pocket-Wizard-Killer" (and compatible) remotes ($AU125.18), from all pre-release reports better range then the PW's.
I also saw that LPA has an Einstein-compatible module in the works, but that one won't be available for several months whereas hopefully my Einsteins won't be much more then a month or so away, so now I'm asking myself do I go for the PCB remotes or the Phottix...For the same price for "non +" versions ???
AB.
Wed Jun 16, 2010 5:34 am
This is what I had on my shopping list
2x Einstein Einstein
1x 8.5-Inch High Output Reflector 8.5 HOR
1x The 22” High-Output Beauty Dish Reflector 22HOBD - WHITE
1x Honeycomb Grid Set, 22-inch. 22RHG SET
1x The NEW Vagabond II Portable Power System VAGA
1x Foldable Large Octabox (47") with speedring attached FOB47
1x *NEW* Foldable Stripbox (10" x 36") with speedring attached FSB1036
1x Foldable Stripbox Grid G1036
1x Large Foldable Softbox Grid G3240
1x The LiteMod Barndoors • may be used with or without the LMBD
1x The White Shovel Background Reflector
1x 8.5" Grid Set 8.5HGSET
1x The LiteMod Unit Mainframe UMF
2x Cybersync Transceiver - CSXCV CSXCV
1x Cyber Commander™ COMMANDER
1x 86 PLM
Wed Jun 16, 2010 12:32 pm
Whatever "Phottix" is it can't possibly do what the proprietary Cyber Commander/Einstein combination does. If you have a link for the latest and greatest PW killer, please post it.
Wed Jun 16, 2010 1:59 pm
I believe these are the PW killers referenced:
http://strobist.blogspot.com/2010/06/po ... s-are.html
Sat Jul 10, 2010 3:08 am
Thanks PE...Yes those were the ones I was referring to.
A direct competitor for the PW Plus II units.
None of the bells and whistles of the MultiMax / Flex TT5 / Mini TT1 or the upcoming Einstein-compatible units, just, from all reports, a very good trigger with a couple of extra features compared to the PW Plus II units at a much cheaper price-point.
AB
Last bumped by Alphabug on Sat Jul 10, 2010 3:08 am.
 [ 16 posts ]
