 [ 128 posts ]
Fri Jan 07, 2011 1:49 pm
rgparker wrote:
fredr500 wrote:
Just to complete my prior post, a trip to Lowes and $0.68 later I now have 4 nuts that fit on the PLM speedring bolt. Both speedrings now fit nicely into a small box with the shafts removed and it's a simple matter to screw them in tot he permanently attached bolts when needed. Much less likely to get bent or broken carrying them disassembled.
Makes carrying and storage much better.
Hopefully I'll have time tonight to actually shoot with them.
Fred
Do you have pictures of how you set it up?
Robert
I'll try to shoot some over the weekend, but it should be easy to visualize:
Insert the bolt that came with the PLM thru one of the supplied washers.
Then insert the bolt through the hole in the speedring, with the threads facing out.
Put the second supplied washer over the threads.
Screw the newly purchased nut onto the threads, tightening the entire assembly.
When you want to use the PLM, screw the aluminum extension arm onto the exposed bolt.
When you are done, unscrew the extension, leaving the bolt screwed to the speedring.
No loose parts to lose, no tools required on the shoot.
Fred
Fri Jan 07, 2011 11:31 pm
Conrad wrote:
What?!?! How did that happen? I ordered mine back on Oct 5th! :(
OK! My bad: I called and verified when I first ordered...Oct 3rd...2 days before you did!
Sat Jan 08, 2011 6:20 pm
Fred
Robert
I did this to all three of my PLM cages when I received them months ago:
Dave F.
Sat Jan 08, 2011 7:10 pm
I received my 86" silver plm v2 and find it somewhat too specular for my tastes, and prefer the softer silver of the plm v1. Is there any chance of offering a version in the softer silver? I realize there would be a trade off in efficiency.
Sat Jan 08, 2011 9:45 pm
Thanks, Fred. I see what you did now. It would make set up much quicker.
Robert
Sun Jan 09, 2011 2:36 am
There is very little difference in the specularity of the V1 and V2 fabrics. V2 produces more even coverage and better shadow structure than V1 or the knock offs.
Mon Jan 10, 2011 8:28 am
Dave - perfect. I couldn't have shot it better, and your one picture explains all of my words so much better.
Fred
Wed Jan 12, 2011 12:25 pm
Fred: what size nuts did you end up using?
Just got my PLM V2s, but I'm missing the speedring bolts on both of them :-( I'll let the tech support folks now..
Wed Jan 12, 2011 2:40 pm
the bolts are 5/16-24, 1" long. I will also make customer service aware of this omission.
Wed Jan 12, 2011 3:31 pm
What TS said, 5/16-24. Note the -24, which is a finer thread than normal. The bins were full of 5/16-10 (or 12?), you need the -24.
Fred
 [ 128 posts ]
