 [ 82 posts ]
Wed Aug 04, 2010 1:04 pm
I just started using my new CC this weekend for the first time and on each of my first two shoots it rebooted, firing both my Einsteins, when I hit the meter button. I probably only metered 10 times or less in each of these shoots, so not the best success rate.
Wed Aug 04, 2010 2:57 pm
Tim and Munzzzzzzz, did you verify battery position and terminal contact as described earlier?
Wed Aug 04, 2010 3:03 pm
just started using my replacement CCs yesterday and today. Both are rebooting right out of the box. I don't think it's a battery contact thing anymore. It's the right joystick that is doing it!
Wed Aug 04, 2010 4:12 pm
has anyone tried the left joystick? This is pretty much doing the same thing as the right, except metering. if anyone has, is there a similar rate of reboot?
Wed Aug 04, 2010 4:55 pm
I've had 0 reboots using the left joystick
Thu Aug 05, 2010 4:39 am
My battery contacts, etc, are all in good shape. I don't have problems with the left joystick - only the right.
Tim
Thu Aug 05, 2010 10:44 am
As best I can tell, everything looks fine with my batteries. The contacts seem to be in the right location and the batteries seem to be making good contact with them. The batteries I'm using are the ones that came with the CC, which I just received, and I had problems within the first few minutes of usage.
Thu Aug 05, 2010 11:56 am
Thanks for the feedback. We are looking into it.
Thu Aug 05, 2010 5:35 pm
Found something interesting while on a shoot yesterday.
If you press the right joystick while the CC tries to reboot it interrupts the reboot cycle and the CC immediately goes back to normal. Like it never tried to reboot.
Don't know if this is something that only works with the CC I've got or if it'll work with all the other CCs out there.
Thu Aug 05, 2010 6:11 pm
how about that - I'll give that a try in the morning
 [ 82 posts ]
