Thu Dec 31, 2009 11:53 pm
Do they came with Strobe unit orders? Or do you have to buy one to go with it?
Fri Jan 01, 2010 10:32 am
Dummy plugs are separate, but the included sync cord can perform the same function
Fri Jan 01, 2010 9:54 pm
Question.
Will the Einstein need a dummy plug (or sync cable plugged into nothing) to disable the slave tripping when the transceiver module is plugged in, or will the transceiver module automatically disable the slave tripping?
Mon Jan 04, 2010 9:56 am
The slave eye can be turned off via menu function.
TS
Users browsing this forum: No registered users and 42 guests
