Adaptable
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1005
Author:  Dwight [ Sat Nov 13, 2010 8:44 am ]
Post subject:  Adaptable
I am thinking about purchasing a beginer bee setup but I had a question. Can your lightstand/umbrella be adapted to use my Nikon SB600/900? At times it would be easier to use the Nikon CLS system rather than studio lights. If they are adaptable what would I need and where would I get such adapters.
Dwight
Author:  fazmanicg [ Sat Nov 13, 2010 12:20 pm ]
Post subject:  Re: Adaptable
Something like this should do.
http://www.calumetphoto.com/1/1/670-umb ... lumet.html
Author:  BigIronCruiser [ Sat Nov 13, 2010 3:52 pm ]
These shoe adapters are also very handy for mounting speedlights:
http://www.bhphotovideo.com/c/product/52772-REG/Stroboframe_300_SHO_Flash_Mount_Adapter.html
By the way, in my experience, CLS works reasonably well indoors, but you really need some type of radio trigger when shooting outdoors. YMMV.
Author:  Dwight [ Sun Nov 14, 2010 9:17 am ]
Thanks for the info. The speedlights would only be use for very specific indoor events. It appears that the Calcumt adapter has a speedlight mount built in. Is that correct?
Dwight
Author:  BigIronCruiser [ Sun Nov 14, 2010 8:09 pm ]
If the Calumet has a built-in speedlight mount, you still might want to have them confirm that it works with an SB-900. The foot on the 900 is a bit thicker than "normal", so it wouldn't work with my first Lastolite EZYBOX. Lastolite, by the way, has "upgraded" their mounts to eliminate this little problem.
