| ABR 800 and Cyber Commnder http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1015 |
| Author: | JimThibert [ Wed Nov 17, 2010 7:22 am ] |
| Post subject: | ABR 800 and Cyber Commnder |
Can someone please advise me how to best operate my ABR800 Ringflash with my CyberCommander onboard a Canon 40D ro 5D while also running 2 Einsteins? Can I continue to plug the ABR800 into the PC socket with the Sync cord and the Cyber Commander simulataniously use the hotshoe? Thanks JImmy |
| Author: | PowerEngineer [ Wed Nov 17, 2010 7:47 am ] |
| Post subject: | Re: ABR 800 and Cyber Commnder |
JT- I'm not sure I'm qualified to say which way is best but I use a similar setup to yours except that I run a CST on the 5Dii and hand hold the CC. Most of the time I just use the slave eye on the ABR 800 because I prefer not having it tethered to the camera. You should be fine with the PC cord too though. |
| Author: | Technical Support [ Wed Nov 17, 2010 10:44 am ] |
Either set up would work. However, the control of the ABR would not be integrated with the Einsteins if the ABR did not have its own plus version reciever. I understand the argument that the controls are there at the camera and easy to get to, but the metering, simulataneous adjustment, etc. would not be available. |
| Author: | PowerEngineer [ Wed Nov 17, 2010 11:57 am ] |
That's true and from a total integrated system standpoint makes the most sense. I should have mentioned that I'll most likely end up getting a + receiver for the ABR800 down the road... but for now have been spending $ on other stuff like modifiers. |
| Author: | JimThibert [ Fri Nov 19, 2010 6:57 am ] |
Thanks to everyone for the advice. Looks like a +Receiver is the answer. I still need to use my light meter for spot controls and so the PC socket is a must for my sekonik. JImmy |
