Sat Nov 20, 2010 3:56 am
Hello !
The Einstein specs says it works with up to 265 VAC,
but on the Europe site it says that 220v areas are delayed for tech. reasons.
is that due to law and certifications, or real technical issue preventing use with 220v ?
in other words:
if i order the einstein on the US shop, and take it to europe, will it work correctly on 220v ?!
Thanks !! ;)
Sat Nov 20, 2010 9:30 am
This should answer your question:
http://www.paulcbuff.com/pcb2009/e640v2.html
In short, if you order now you'll get the new version.
Sat Nov 20, 2010 9:55 am
I've read that.
just want to make sure i can order from the US store to use with 240v
Mon Nov 22, 2010 9:59 am
Yes, any new unit you get from the US, UK, or Australia will work fine on 240VAC.
Users browsing this forum: Google [Bot] and 31 guests
