| Vagabond (the original) Has Not Been Charged in Over 1 Year http://paulcbuff-techforum.com/viewtopic.php?f=8&t=102 |
| Author: | mahero [ Sat Jan 02, 2010 6:42 pm ] |
| Post subject: | Vagabond (the original) Has Not Been Charged in Over 1 Year |
I am the owner of the original Vagabond portable Power System. Due to a physical move and other factors, I was not able to charge my unit in over a year. What do I do to get it back into operational condition? Thanks |
| Author: | Technical Support [ Mon Jan 04, 2010 10:20 am ] |
| Post subject: | Re: Vagabond (the original) Has Not Been Charged in Over 1 Year |
You can first try to charge teh unit, and see what will happen (i.e. see if it will hold a charge). Likely it will not. At this point a simple battery replacement ($39.95) will get you going, assuming all other components are performing properly, and there should not be any reason they don't. TS |
