Mon Dec 06, 2010 3:49 pm
I would like to know if anyone has a good technique for converting color temperature when using the Einstein in conjunction with the PLM modifiers? It seems you'd have to surround the flash tube with a gel yet keep it from melting. Any good techniques out there?
Thanks!
Mon Dec 06, 2010 4:03 pm
You could wrap a cone of gel around the PLM cage. You may need to look for high temperture rated gels and/or reduce the intensity of the model lamp.
Mon Dec 06, 2010 4:05 pm
A cone around the cage....good idea. I'll give it a try!
Users browsing this forum: No registered users and 23 guests
