Vagabond: mini or not?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1035
Author:  MBisom [ Sun Nov 28, 2010 4:18 pm ]
Post subject:  Vagabond: mini or not?
What would be the advantage of the Vagabond II over the mini?
Author:  PowerEngineer [ Sun Nov 28, 2010 7:03 pm ]
Post subject:  Re: Vagabond: mini or not?
I think the electronics on the Vii are rated to handle more lights (Ws) than the mini and recycle faster. The Vii is also A LOT heavier which can be a benefit if you are using it to sandbag a stand. I guess one other advantage would be the ability to find lead acid batteries just about anywhere in the event that your battery died and you absolutely had to shoot with portable power.
Check out the discussion here: viewtopic.php?f=8&t=861&start=0
