| Setting ISO on CC http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1039 |
| Author: | thrumyeyes [ Tue Nov 30, 2010 4:23 pm ] |
| Post subject: | Setting ISO on CC |
Hi All, It's my first post here. I am a complete newbie to PCB products and am having a little trouble with the CC. I have 2 Einsteins , a CC and 2 CSXCV plus light modifiers, etc. I am also shooting with Nikon D700 and D300 cameras which have a base ISO of 200. The default settings on the CC seem to be ISO 100 and 1/250 shutter speed. I have read the instructions supplied but cannot understand how I adjust the ISO and shutter speed settings on the CC. I want to change the settings to ISO 200 but cannot seem to do it. I had assumed that the CC would read the ISO on my D700 then adjust accordingly but it is not doing this. It just remains at ISO 100 no matter what I have the camera set at. Sorry for the newbie question. I would appreciate any advice that you can throw my way! Cheers Allan |
| Author: | Technical Support [ Tue Nov 30, 2010 4:50 pm ] |
| Post subject: | Re: Setting ISO on CC |
The CyberSync system and you camera will not communicate with each other except to pass a "fire" command. To adjust the ISO, go to SETUP>FLASHMETER>then use the left joystick up and down to adjust ISO. Using the same joystick left and right will adjust shutter speed. |
| Author: | thrumyeyes [ Tue Nov 30, 2010 5:00 pm ] |
Technical Support wrote: The CyberSync system and you camera will not communicate with each other except to pass a "fire" command. To adjust the ISO, go to SETUP>FLASHMETER>then use the left joystick up and down to adjust ISO. Using the same joystick left and right will adjust shutter speed. OK, thanks for that! I had wrongly assumed that it would track the camera's settings. Cheers |
| Author: | PowerEngineer [ Tue Nov 30, 2010 6:20 pm ] |
thrumyeyes wrote: OK, thanks for that! I had wrongly assumed that it would track the camera's settings. The CC is slick but it isn't that slick ;) |
| Author: | fredr500 [ Wed Dec 01, 2010 4:07 pm ] |
Alos, be aware that if the CC resets (even if the batteries just lose contact for a bit) the ISO and shutter speed default to factory settings, they are not remembered. Don't ask how I found this... Fred |
