einstien modeling lamp
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1059
Author:  stealthhunterdk00 [ Sat Dec 11, 2010 10:42 pm ]
Post subject:  einstien modeling lamp
my einstein V2 modeling lamp will not turn off when pressing the buttons on the back of the unit.
function-model-arrow up-arrow up-arrow up. it stays fairly bright even though the model mode screen shows "off". help please
Author:  Technical Support [ Sun Dec 12, 2010 6:34 pm ]
Post subject:  Re: einstien modeling lamp
Are you also using a Cyber Commander?
Author:  stealthhunterdk00 [ Sun Dec 12, 2010 7:53 pm ]
yes
Author:  Technical Support [ Sun Dec 12, 2010 10:13 pm ]
Try removing the Transciever and see if it works normally from the head.
Author:  stealthhunterdk00 [ Sun Dec 12, 2010 10:29 pm ]
tried that already and again just now, still is not turning off the modeling lamp even the is says the model is off.
Author:  Technical Support [ Mon Dec 13, 2010 1:36 pm ]
That is then an internal fault. Please contact Customer Service for replacement.
Author:  Liquid Rhino [ Mon Jan 24, 2011 10:41 am ]
Same thing just started happening to one of mine during a shoot yesterday :oops: Was fine until now. Light will adjust power from mid-to-full and back down to mid, but never any lower than that. Rear buttons or CC set it to off (menu states 'off') but light remains at mid power.
edit: Solved, but did need to be sent in. THANKS CS! :D
