| Vagabond Mini Lithium - GFCI http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1106 |
| Author: | CanadianEh [ Fri Jan 07, 2011 7:27 pm ] |
| Post subject: | Vagabond Mini Lithium - GFCI |
Does the Vagabond Mini have a built-in ground fault circuit interrupter (GFCI) like the Vagabond II? |
| Author: | Photodan [ Sun Jan 09, 2011 11:35 pm ] |
| Post subject: | Re: Vagabond Mini Lithium - GFCI |
Good question. I sometimes get caught outside in the rain, although I try to protect everything at a moments notice, I take care of my cameras and than the lights. The power comes last. If this thing gets wet, will it ruin my day? |
| Author: | Luap [ Mon Jan 10, 2011 2:42 am ] |
A complete study of codes and safety considerations has shown there is no need for a GFIC. No other inverter based battery supply, nor Quadra Rangers, etc., to our knowledge, use a GFIC. There are provisions on the Vag Mini to attach an earth ground if desired, but there seems to be no real world need for it. |
| Author: | bill@wkrp.com [ Mon Jan 10, 2011 5:13 pm ] |
So what changed between the Vagabond II that has a GFIC and the Vagabond Mini that doesn't? Was it actually not needed on the VII and just there from an abundance of caution? It's not going to affect my purchase either way. I'm just curious. If I really feel I need GFIC I can buy one of these: http://www.amazon.com/Tripp-Lite-TLM609 ... B000WJB1O8 |
| Author: | Luap [ Mon Jan 10, 2011 9:06 pm ] |
Abundance of caution. We have not had good success with off the shelf GFIC units . . . they won't tolerate the lowered voltage during recycle and usually shut down or chatter off and on. |
| Author: | mill4570 [ Tue Jan 11, 2011 2:56 pm ] |
Luap wrote: Abundance of caution. We have not had good success with off the shelf GFIC units . . . they won't tolerate the lowered voltage during recycle and usually shut down or chatter off and on. Hmmmmmm....This may explain why my VII will shutdown for no apparent reason, but will restart after I turn the power switch off for 5 seeconds then back on. If I send the VII inverter back, can you disable the GFIC? Richard K. |
| Author: | Technical Support [ Tue Jan 11, 2011 5:31 pm ] |
mill4570 wrote: Hmmmmmm....This may explain why my VII will shutdown for no apparent reason, but will restart after I turn the power switch off for 5 seeconds then back on. If I send the VII inverter back, can you disable the GFIC? Richard K. No, the circuitry was designed with the GFI inplace. However, the inverter can be sent in and we can correct the issue you are having of the inverter shutting down. |
| Author: | mill4570 [ Wed Jan 12, 2011 10:17 am ] |
Technical Support wrote: mill4570 wrote: Hmmmmmm....This may explain why my VII will shutdown for no apparent reason, but will restart after I turn the power switch off for 5 seeconds then back on. If I send the VII inverter back, can you disable the GFIC? Richard K. No, the circuitry was designed with the GFI inplace. However, the inverter can be sent in and we can correct the issue you are having of the inverter shutting down. I have two VMLs on the way. As soon as they arrive I'll send the VII inverter in for this mod. Can I send just the iverter (no bettery or case)? Apologies to the OP......for hijacking the thread. Richard K. |
| Author: | Technical Support [ Wed Jan 12, 2011 11:06 am ] |
mill4570 wrote: Can I send just the iverter (no bettery or case)? Richard K. In this particular instance, yes. Be sure to fully charge the battery before you send teh inverter in, as well as be absolutely sure the battery does not short (i.e. don't let the wires touch) while not attached to the inverter. |
