EINSTEINs and VML/ modeling light
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1114
Author:  Watt Sekont [ Tue Jan 11, 2011 6:21 pm ]
Post subject:  EINSTEINs and VML/ modeling light
Congrats for rolling out the Vagabond Minis and good luck in using them for the shooters.
The PCB website states:
"Like essentially all battery/inverter type supplies, modeling lamps are not generally used because their power draw would quickly deplete the battery and slow recycle times dramatically."
Will a fully charged 1x VML support 2x EINSTEINs 250W-modeling-lamps-operation for a few minutes in total? And continue 2x 80 flashes at appr. 60% power?
Thanks.
Author:  phs [ Tue Jan 11, 2011 6:41 pm ]
Post subject:  Re: EINSTEINs and VML/ modeling light
Page 2 of the manual "The Warnings!" states "The Vagabond Mini Lithium cannot power a 250W modeling lamp at full power" - and goes on to mention that they are in the process of acquiring a special 50W lamp that could be used for brief periods.
Author:  Watt Sekont [ Tue Jan 11, 2011 6:44 pm ]
hhhhmmmmm.
Thank you.
Author:  PowerEngineer [ Thu Jan 13, 2011 10:10 am ]
The VML inverter is rated at around 130 watts continuous output. Two x 250 watt modeling lamps are going to be pulling around 500 watts continuous so you are limited not just by how fast you'll deplete the battery but also by the output capacity of the inverter.
Author:  Watt Sekont [ Thu Jan 13, 2011 2:25 pm ]
Hello PowerEngineer,
where did you get the "130 watts continuous output"-info from?
Thanks clearing this up.
Author:  Technical Support [ Thu Jan 13, 2011 2:51 pm ]
It is actually a 120 continuous Watt inverter.
Author:  PowerEngineer [ Fri Jan 14, 2011 8:59 am ]
Thanks for the clarification TS.
@Watt... I remembered it from some posts on this forum a while back.
