| CSR+ > CSRB+ http://paulcbuff-techforum.com/viewtopic.php?f=8&t=114 |
| Author: | kiem [ Tue Jan 05, 2010 7:34 pm ] |
| Post subject: | CSR+ > CSRB+ |
Well, couple things I discovered with the CSRB+ that I dont like about. (1) Having to press the test/power button each time for it to work with the CC. (2) This is the main thing, once the green led stops flashing or goes to sleep, my strobe's model lamp is turned on. This is no longer a standby mode. I'm returning this to get the CRS+ instead. I bought this thinking if I need to use it for my SB800/SB900 on the go, I can take the battery operated one. |
| Author: | Technical Support [ Wed Jan 06, 2010 12:32 pm ] |
| Post subject: | Re: CSR+ > CSRB+ |
On the first point, do you mean pressing it to turn it on before a session? Or was there another need you are experiencing? For the exchange, you can send it in and request the exchange, assuming you are within the first 60 days. For any further correspondence for this, please contact customer service at 1-800-443-5542 or at info@paulcbuff.com TS |
| Author: | kiem [ Thu Jan 07, 2010 1:07 am ] |
Right, pressing before each session. This is no longer issue since Paul confirmed putting them on standby mode using CC doesnt mean turning them off completely. I was hoping "standby" means turning them off with convenient of the CC - need to get my lazy a** on that ladder to switch the buttons. No returns needed. Thanks. |
