| USK "Spill Kill" reflector kaput? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1197 |
| Author: | tetrode [ Thu Feb 10, 2011 9:36 pm ] |
| Post subject: | USK "Spill Kill" reflector kaput? |
It appears that the ultra-shallow USK "Spill Kill" reflector has been discontinued. The only umbrella reflector I now see listed on the AB site is the one formerly sold as the PLM V1 reflector. It really isn't a USK work-alike. Here's my question: I do own a USK reflector but it cannot be mounted snuggly on my Einsteins. The mounting fingers do not grab the USK at all which allows it to wobble and spin freely (though it can't fall off). Are there any plans for an Einstein-friendly version of the USK? If not, may I suggest you consider producing one. Dave F. |
| Author: | mrscott [ Fri Feb 11, 2011 10:08 am ] |
| Post subject: | Re: USK "Spill Kill" reflector kaput? |
Along the same lines, is this an option for production? Elinchrom Wide Angle Reflector, 9-1/2", 135 Degrees With a hole to allow the 22" beauty dish deflector to produce this type of setup. Reflector mounted on strobe with deflector installed |
| Author: | Technical Support [ Fri Feb 11, 2011 3:12 pm ] |
neither of these are currently in the works, however the suggestions are noted and will be passed along. |
