Wed Feb 16, 2011 2:52 pm
I need input on a reflector. I am lighting through a 8'x8' and a 10'x20' silk butterfly. The fabric is approx. a 2s loss. My thinking was 1 head on the 8x8 and 3 heads on the 10x20, but which reflector will cover approx. 70 sq. ft. in the most even manner without taking up too much distance behind the silk. I was thinking the large plm, but then I saw 45 degree output. So........ Thanks for any and all suggestions.
Wed Feb 16, 2011 7:00 pm
The best reflector for this is, believe it or not, the 7 inch that came with your lights, with a barn door set (trust me, it's necessary). The 7 inch will completely cover an 8 foot silk from 6.7 feet away (I usually pace off 6 feet and say "close enough"). That produces a round spot of light 11.2 ft in diameter, which is why you need the barn doors, to eliminate the stuff that spills past the silk at top, bottom, and sides.
Paul's set costs about $110 for the Mod Lite frame and the barn doors, and it's great, the frame also lets you mount snoots. The barn doors are rectangular flaps, and I prefer expanding barn doors, so 2 of my Paul Buff 7 inch reflectors are outfitted with Lowel Omnilite barndoors. You "commit" a Paul Buff reflector to Lowel barndoors, it took two people stretching the barndoor frame to get it on the reflector, and I don't think I can ever get it off again.
At 6.7 feet, you have 40 degrees divergence from perpendicular at the corners of the scrim, which is enough to give a substantial hot spot in the center for most silks. If you've got enough light that you can afford to lose a stop, backing up to 9.4 (or 9) feet will decrease divergence to 30 degrees, and the light looks much more even. And makes the barndoors ever more necessary.
If you can get the space, the 8.5 high output is a great reflector behind a flat. The calculations say it has to be 13.6 feet back to cover the corners of an 8 foot flat, but I usually just pace off 12 feet. This combination has as high a light output as the 7 inch reflector at 6 feet, but it's so much more even. One of my 8.5 inch HORs wears a Norman 10 inch barndoor set with a homebrew wire mount. (Hey Buff guys, how about barn doors for the 8.5 HOR, now that you've got grids?)
The PLM theoretically can light an 8 foot flat from 13 feet, but I don't want to see how you flag the spill. ;)
I also sometimes light a flat with a 16 inch Photogenic, modified to fit the Paul Buff mount, with Photogenic's 2 door barn door set. I should have the 4 door. Say $300 for reflector and barn doors, and about 20 minutes with a nibbler to fit it to the Buff mount.
Thu Sep 22, 2011 3:38 pm
joe, i recently worked in a studio that is all photogenic, poor bastards, but i did love the 16" reflector with hard diffusion and barn doors. we have some spare inner rings for the PB speedrings but not the imagination to figure-out how to attach them to the PL16- is it truly just cut the hell out of it till it fits?
Thu Sep 22, 2011 4:16 pm
Joseph,
Are you using the main frame that is shiny or the matte finish mainframe? We have, in recent years, switched from a shiny finish to a duller more even finish.
Users browsing this forum: No registered users and 78 guests
