| Radioremote one with WL 10000 http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1232 |
| Author: | kb8man [ Wed Feb 23, 2011 12:52 pm ] |
| Post subject: | Radioremote one with WL 10000 |
What do I need to use radioremote one units with WL 10000. I have a chance to purchase a set of radioremote ones and was wondering if they will work and what i need to use them with WL 10000 units. |
| Author: | Technical Support [ Wed Feb 23, 2011 2:49 pm ] |
| Post subject: | Re: Radioremote one with WL 10000 |
You would not be able to adjust power on a wl1000 as it lacks the RJ11 connections. |
| Author: | kb8man [ Thu Feb 24, 2011 1:07 pm ] |
I am aware that I can not adjust the power levels. The WL site said they can be used here is the "The WL Series units may be used with our RadioRemote One, but they require a different connection and can only be used as a firing mechanism, not adjusting the output settings." So I am wondering what other connection I will need in able to use them? Thanks |
| Author: | Technical Support [ Thu Feb 24, 2011 2:01 pm ] |
For triggering, they would require a 1/8 to 1/4" male cord. The "different connection" would be the RJ11 connection that is used for adjustment. |
