| Channels vs Groups http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1245 |
| Author: | Sty1 [ Wed Mar 02, 2011 7:49 am ] |
| Post subject: | Channels vs Groups |
I have two Einsteins one is assigned Ch 1 in Grp 1 and one is assigned Ch2 in Grp 2. After many hours of trying, I cannot get the lights to fire separatly when metering (either by group or by channel). Both are on the same frequency. Where is the "addendum" to the CC manual online? |
| Author: | Technical Support [ Wed Mar 02, 2011 10:04 am ] |
| Post subject: | Re: Channels vs Groups |
The addendum for Einstein by itself is not posted online, as the material covered is incorporated into the current manuals. The problem you are experiencing is likely due to the slave eye being active. It should be turned off via the Cyber Commander: SET UP>LIGHT SETTINGS> select "ALL" channel setting> SLAVE EYE=OFF. At that point, each light will trigger independently. |
| Author: | Sty1 [ Fri Mar 04, 2011 9:29 am ] |
Thanks. That was it. |
