Wed Mar 09, 2011 10:01 pm
This probably has been asked in the past, but I can't find it due to the keywords are too popular...
Can I use the CSRB's / CST to trigger a camera's shutter remotely? If so, how, and what extra parts would I need?
Also, is there a way to use the CST, AND shoot with an on camera flash? Again, what would I need?
Thanks,
Dave
Thu Mar 10, 2011 9:39 am
Here is a good place to start. The topic can be tough to search for if you don't know what parts (search terms) you need :D
viewtopic.php?f=8&t=513&p=3109&hilit=drive+cable#p3109
Thu Mar 10, 2011 11:01 am
Which camera?
Thu Mar 10, 2011 12:22 pm
Technical Support wrote:
Which camera?
5dmk2 and 1dmk3
Thu Mar 10, 2011 1:14 pm
From my experience thus far, either the CSRB or CSRB+ will work for Canon DSLR's (I have yet to see one not work). You will need a prerelease cable, we have tested with the Flash Zebra versions. You will not have remote AF activation. It would be either continuous AF or MF (or, I guess, a fixed pre-aquired focus is possible). One press of the CST=one shot on the camera, no "motor drive". The remote camera will be a fraction of a second behind teh master camera, as the master is already exposing when the remote camera is getting the signal to raise the mirror/shutter. This will make syncing lights with both a little more...challenging.
An on camera flash can be used in either camera, with the CST connected via PC port, and CSRB connected to N3 connector.
