| CyberSync to trigger a Camera http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1270 |
| Author: | Camara Photography [ Wed Mar 09, 2011 10:01 pm ] |
| Post subject: | CyberSync to trigger a Camera |
This probably has been asked in the past, but I can't find it due to the keywords are too popular... Can I use the CSRB's / CST to trigger a camera's shutter remotely? If so, how, and what extra parts would I need? Also, is there a way to use the CST, AND shoot with an on camera flash? Again, what would I need? Thanks, Dave |
| Author: | PowerEngineer [ Thu Mar 10, 2011 9:39 am ] |
| Post subject: | Re: CyberSync to trigger a Camera |
Here is a good place to start. The topic can be tough to search for if you don't know what parts (search terms) you need :D viewtopic.php?f=8&t=513&p=3109&hilit=drive+cable#p3109 |
| Author: | Technical Support [ Thu Mar 10, 2011 11:01 am ] |
Which camera? |
| Author: | Camara Photography [ Thu Mar 10, 2011 12:22 pm ] |
Technical Support wrote: Which camera? 5dmk2 and 1dmk3 |
| Author: | Technical Support [ Thu Mar 10, 2011 1:14 pm ] |
From my experience thus far, either the CSRB or CSRB+ will work for Canon DSLR's (I have yet to see one not work). You will need a prerelease cable, we have tested with the Flash Zebra versions. You will not have remote AF activation. It would be either continuous AF or MF (or, I guess, a fixed pre-aquired focus is possible). One press of the CST=one shot on the camera, no "motor drive". The remote camera will be a fraction of a second behind teh master camera, as the master is already exposing when the remote camera is getting the signal to raise the mirror/shutter. This will make syncing lights with both a little more...challenging. An on camera flash can be used in either camera, with the CST connected via PC port, and CSRB connected to N3 connector. |
