| Einstein will power up, but not flash http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1277 |
| Author: | v8mb [ Sat Mar 12, 2011 12:40 am ] |
| Post subject: | Einstein will power up, but not flash |
So I just unpacked my Einsteins and got them set up. I'm in India and taking advantage of the 220v feature. I Set two of the units on 64th power and did a series of test fires (5 flashes in a row). Great, everything work. But, less than a minute later, when I went to test them again, one of the two units has a red "ready" button and won't fire. The modeling lamp also does not come on. I unplugged the unit, turned it off and on, tried the plug from the working unit, tried a new modeling lamp, tried a new flash tube, nothing worked. Has this happened to anyone else? Any advice? Sending the unit back to the States for inspection would take two weeks each way. - Thanks |
| Author: | martinhallberg [ Mon Mar 14, 2011 3:03 am ] |
| Post subject: | Re: Einstein will power up, but not flash |
I had the exact same problem, only solution was to send it back for a replacement. I live in sweden so it was a bit of hassle for me to but it all worked out great. |
| Author: | Technical Support [ Mon Mar 14, 2011 8:58 am ] |
If the red light will not turn green, then the unit will need to be serviced or replaced. Contact the distributor from whom you ordered the light to arrange this. |
