Thu Jan 07, 2010 9:49 pm
Modeling
The Einstein specs a 250 watt Quartz modeling lamp.
The AB 1600 specs a 150 watt Edison-base lamp.
Is there a base-coverter to allow the 250 quartz to be installed in an AB1600?
Thu Jan 07, 2010 11:36 pm
No. You can use a 250W Edison base lamp ala WL if you're careful with heat build up,
