| Modeling lamps for Einstein http://paulcbuff-techforum.com/viewtopic.php?f=8&t=129 |
| Author: | bbphoto [ Thu Jan 07, 2010 9:49 pm ] |
| Post subject: | Modeling lamps for Einstein |
Modeling The Einstein specs a 250 watt Quartz modeling lamp. The AB 1600 specs a 150 watt Edison-base lamp. Is there a base-coverter to allow the 250 quartz to be installed in an AB1600? |
| Author: | Luap [ Thu Jan 07, 2010 11:36 pm ] |
| Post subject: | Re: Modeling lamps for Einstein |
No. You can use a 250W Edison base lamp ala WL if you're careful with heat build up, |
