1/8" dummy plugs...with CC
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1296
Author:  PaulAuclair [ Tue Mar 15, 2011 8:23 pm ]
Post subject:  1/8" dummy plugs...with CC
reading the CC manual (do not have the CC yet). on page 8 under "Initial Set up" the picture and literature says to plug in 1/8 dummy plugs (to disable slave eye) before plugging in CSR(B)+ receiver(s).
I thought we did not have to use dummy plug(s) when plugged in to telephone jack?
Paul
Author:  Technical Support [ Wed Mar 16, 2011 8:51 am ]
Post subject:  Re: 1/8" dummy plugs...with CC
You do not have to use the sync jack for triggering when using the RJ11 remote jack. However, the RJ11 jack does not have a slave eye cut out switch in it. Therefore, the only way to disable the slave eye is to plug something into the sync jack.
Author:  PaulAuclair [ Wed Mar 16, 2011 12:10 pm ]
thnx.
does the same go for E640 when they have their receivers plugged in?
Author:  rms956 [ Wed Mar 16, 2011 7:40 pm ]
Quote:
•With the Cyber Commander™, when the Einstein™ is not in a selected group, the new firmware turns off its modeling lamp and disables the sync jack and slave eye
This is when the Version32 firmware is applied to the CC.
RMS
Author:  Luap [ Thu Mar 17, 2011 12:47 am ]
PaulAuclair wrote:
thnx.
E640 has a slave on/off function in the function menu.
