| VB Mini Charging http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1305 |
| Author: | lpeeples [ Fri Mar 18, 2011 2:31 pm ] |
| Post subject: | VB Mini Charging |
Just got a VB Mini... question on charging. The book says to turn the unit off, and plug it in and the LED is supposed to light to show charging, however, nothing lights up. I assume its charging, but wanted to check if I should turn it on to charge? |
| Author: | Technical Support [ Fri Mar 18, 2011 3:07 pm ] |
| Post subject: | Re: VB Mini Charging |
There is an LED on the charger block. Red means it is charging, and green means the charge is complete. |
| Author: | lpeeples [ Fri Mar 18, 2011 3:19 pm ] |
I know that... its under the word "fuse". My question is, my unit swtich is off. With the charging cord plugged in, that LED is not lit. Should it be lit? |
| Author: | Luap [ Fri Mar 18, 2011 4:29 pm ] |
No. The charging indicator is on the charger. |
