Vagabond Mini no charging light
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1312
Author:  gurk [ Thu Mar 24, 2011 12:37 am ]
Post subject:  Vagabond Mini no charging light
I received my Vaga Mini yesterday. It was fully charged when it came. After a little usage and dropping the charge to half, I plugged it in to get it fully charged again. Manual says when its plugged in and charging, red light turns on. In my case it doesn't. But when I turn the unit on after a few hours of charging, it shows full power again so it's actually charging I guess..
Does this mean I just have a melfunctioning led and I can use the unit with no problems otherwise? I just got this thing after 2 months of wait and it'd be a pain to send it back for repair.
Author:  ZacWong [ Thu Mar 24, 2011 7:38 am ]
Post subject:  Re: Vagabond Mini no charging light
I was thinking the same thing when mine arrived. I thought that there would be a light on the unit, but the red/green light is actually on the charger. The little box shows when it is charging, and when it is not.
Author:  Technical Support [ Thu Mar 24, 2011 1:54 pm ]
Yes, that does reference the external charger's LED.
Author:  gurk [ Sun Mar 27, 2011 5:35 pm ]
Soooooo, it's faulty? Sorry I couldn't comprehend.
Author:  Luap [ Sun Mar 27, 2011 7:03 pm ]
No, it's not faulty . . . the charging light is on the charger, not on the VML front panel.
Author:  Technical Support [ Mon Mar 28, 2011 9:25 am ]
Only if you are not getting a red LED on the charger block (the box that is part of the cable that goes to the wall). The Vagabond inverter itself will not have a red light.
